AMENT issues in Ros...
AMENT issues in Ros2
duanemclemore
(@duanemclemore)
Hi All,
I am trying to install ROS2 using the packages from @Kevin DeMarco and RIF-Robotics. Which looks very promising! However, during the build for the AR-3 software, I always encounter the following error with the AMENT compilation.
What am I doing wrong?
  • ros2 Foxy is properly installed and tested to work.
  • The files downloaded from the RIF-Robotics github haven't been altered.
  • ament_cmake_mypy and the other files seem to be installed in the right (default) places.
  • I've gone through the .bash and .sh files to see where my paths might be misdirecting the CMAKE_MODULE_PATH.
  • Error printout to the terminal below
Has anyone else run into this issue?
Thank you in advance for your help!
--- stderr: ar3_bringup
CMake Error at CMakeLists.txt:26 (find_package):
  By not providing "Findament_cmake_mypy.cmake" in CMAKE_MODULE_PATH this
  project has asked CMake to find a package configuration file provided by
  "ament_cmake_mypy", but CMake did not find one.
  Could not find a package configuration file provided by "ament_cmake_mypy"
  with any of the following names:
    ament_cmake_mypyConfig.cmake
    ament_cmake_mypy-config.cmake
  Add the installation prefix of "ament_cmake_mypy" to CMAKE_PREFIX_PATH or
  set "ament_cmake_mypy_DIR" to a directory containing one of the above
  files.  If "ament_cmake_mypy" provides a separate development package or
  SDK, be sure it has been installed.
