Basic programming o...
Basic programming of nema 11 stepper motor with arduino
Kenny T
(@kenny-t)
I bought the nema 11 motor with a gearbox with a gear ratio of 13.73:1 plus a dm320 driver, and made the connection to the arduino. Where PUL = 5, DIR = 6, and OPTO = 7, Pin 7 is programmed high to be activated with 5v, now when programming I use 1/2 step in the driver configuration, which is actually 400 steps for my 1.8 degree motor, but since the motor has a gearbox included and I have to change my steps, which would be, 1.8 / 13.73 = 0.13 degrees, which would be 2769.23 steps for one motor revolution, but included at 1/2step = 400 steps in the driver would be 5538.46 revolutions of the motor so that the gearbox can make one revolution. When I program it, the gearbox makes a half turn. My question is, is there a defect with the motor? Is my analysis correct? Or do you have to include something else in the programming?
This is the program:
int x;
int PUL = 5;
int DIR = 6;
int EN = 7;
void setup() {
pinMode(PUL,OUTPUT); //
pinMode(DIR,OUTPUT); //
pinMode(EN, OUTPUT);
digitalWrite(PUL, LOW);
digitalWrite(DIR, LOW);
digitalWrite(EN, HIGH);
void loop() {
digitalWrite(DIR,HIGH); //
for(x = 0; x < 5538.46; x++) //
digitalWrite(PUL,HIGH); //
delayMicroseconds(500); //
digitalWrite(PUL,LOW); //
delay(1000); /
digitalWrite(DIR,LOW); //
delay(1000);
I would be grateful for the answer
