issue J4 TIMING HUB
issue J4 TIMING HUB
5 Users
Avatar of Robin Beck
(@robin-beck)
J4 TIMING HUB does not match with 84XL037 timing belt. Most of the 28 teeth of J4 TIMING HUB work fine. Only three or four teeth are not correct. I tried it with a higher belt tension but it doesn't get better.
Interesting; I have not seen this issue come up yet. @Ari Hant @Matt Carrier have you guys experienced this? do you have any pictures of how your belts aligned on the J4 timing hub?
Ari Hant
(@ari-hant)
I had a bit of hand finish do to poor finish on the hub, but the pitches matched
Harry Olthof
(@harry-olthof)
The belt fits well on the printed version as well as on the aluminum version
(@robin-beck)
here you can see the issue on the right side (the white paper is only for a better contrast)
(@robin-beck)
(@robin-beck)
if i turn j4 timing hub 180° backwards then the issue moves to the left side. I marked this two places in one of the following pictures. The red line is for the right side and the blue line for the left.
(@robin-beck)
(@robin-beck)
(@robin-beck)
Avatar of Matt Carrier
(@matt-carrier)
I haven't built enough of it to properly test that built but it does seem like when rotating it in my hands with the belt it isn't going to grip properly. As I rotate it seems to come out of alignment.
I suspect with these being laser cut and no finish work the OD is probably slightly large and the faces and flanks need polished. As soon as I get my next batch I will certainly review with different belts as well as some finish work and I will get back to you.
I just received the next batch of parts. The belts fit well on this batch so I am unable to replicate the issue but I suspect variance in cutting equipment and materials. I would recommend using a nylon abrasive wheel along the width of the teeth, polishing not only the OD but the faces and flanks of the sprocket - removing any sharp corners should allow the belt to fit as intended.
https://anninrobotics.com/wp-content/uploads/2025/07/issue-J4-TIMING-HUB_6.avif
https://anninrobotics.com/wp-content/uploads/2025/07/issue-J4-TIMING-HUB_7.avif
