j6 axes limit
guy
 guy
(@guy)
Hello,
I just finished to build my AR4 arm and I'm facing an issue. When I try to move an ax, I'm getting a J6 axes limit message and nothing happend.
I'm using AR4 2.1 with sketch v2.0.
I checked all cabling and everything seems to be OK. I also disconnectet the ethernet cable no 3. I'm always getting the same message.
Does anyone have an idea about this issue ?
With kind regards, Guy.
guy
 guy
(@guy)
Hello,
I installed Teensy sketch 2.2 and AR4 V2.2. I forced cal to 0° and force cal to vert. All sliders are set to 0. Then, I moved J4 a bit and it turned. I notices that J6 slider went to maximum, while it did not move, the message "J6 Collision or Motor Error" or "J6 Axis Limit" is displayed and the system is completely locked.
By the way, I can move only J4 before the error message is displayed.
I'm suspecting two potential issues:
- noise on the sensor cables: some signals measured with a scope seems to be rather noisy.
- power issue on the Teensy
Avatar of r8183594
(@r8183594)
@guy
Have you "ticked" the encoder ignore boxes, and tried?
Does the robot "home" all axis to their limit switches?
Avatar of r8183594
(@r8183594)
@guy I'd confirm the limit switch functionality, then calibrate each axis.
guy
 guy
(@guy)
@r8183594 I put a scope on the lines and I noticed they are very noisy. The noise signal is reaching 2V level. I removed all the signal cables and I'm re-cabling with cat6e cables, paying attention to carefully grounding all shield in a star way to avoid ground loops.
