<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Wireless connection instead of USB cable - General Discussion				            </title>
            <link>https://anninrobotics.com/forum/general-discussion/wireless-connection-instead-of-usb-cable/</link>
            <description>Annin Robotics Discussion Board</description>
            <language>en-US</language>
            <lastBuildDate>Sat, 04 Apr 2026 16:59:38 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>RE: Wireless connection instead of USB cable</title>
                        <link>https://anninrobotics.com/forum/general-discussion/wireless-connection-instead-of-usb-cable/#post-1396</link>
                        <pubDate>Wed, 23 Jul 2025 00:06:48 +0000</pubDate>
                        <description><![CDATA[If the drivable platform has a network, you could use something like this:- i&#039;ve never used the USB one, but the RS232 ones work great. theres probably cheaper alternatives as well.  Another...]]></description>
                        <content:encoded><![CDATA[<p><span>If the drivable platform has a network, you could use something like this:</span><span> </span><a class="KuPfL ggJuS" href="https://www.digi.com/products/models/aw02-g300" target="_blank" rel="noopener noreferrer" data-hook="web-link"><u><span>https://www.digi.com/products/models/aw02-g300</span></u></a><span> </span><span>- i've never used the USB one, but the RS232 ones work great. theres probably cheaper alternatives as well.</span><span> </span><span> </span><span>Another option might be put a raspberry pi (4, 5 or zero - with adaptors), connect it to the teensy and install software called virtualhere </span><a class="KuPfL ggJuS" href="https://www.virtualhere.com/" target="_blank" rel="noopener noreferrer" data-hook="web-link"><u><span>https://www.virtualhere.com/</span></u></a><u><span>. I've used virtualhere on another project and it worked fine. you'll have to hotspot to the RPI or do some other networking.</span></u><span> </span><span> </span><span>If you get something working, let us know!</span></p>]]></content:encoded>
						                            <category domain="https://anninrobotics.com/forum/general-discussion/">General Discussion</category>                        <dc:creator>Johann Voigtlander</dc:creator>
                        <guid isPermaLink="true">https://anninrobotics.com/forum/general-discussion/wireless-connection-instead-of-usb-cable/#post-1396</guid>
                    </item>
				                    <item>
                        <title>Wireless connection instead of USB cable</title>
                        <link>https://anninrobotics.com/forum/general-discussion/wireless-connection-instead-of-usb-cable/#post-1395</link>
                        <pubDate>Wed, 23 Jul 2025 00:06:35 +0000</pubDate>
                        <description><![CDATA[Hi,
I&#039;m curious what device are you using to connect to the robot wirelessly?
My Robot-Arm will be sitting on a drivable plattform, and I don&#039;t want to run behind the AR4 with an USB cable...]]></description>
                        <content:encoded><![CDATA[<p id="viewer-foo" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>Hi,</span></span></p>
<p id="viewer-h9jlz1089" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>I'm curious what device are you using to connect to the robot wirelessly?</span></span></p>
<p id="viewer-o9i981464" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>My Robot-Arm will be sitting on a drivable plattform, and I don't want to run behind the AR4 with an USB cable.</span></span></p>
<div id="viewer-w0ugo2600" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"> </span></div>
<p id="viewer-3p3nd2610" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>I was looking into wireless USB dongles, but not sure if this will work.</span></span></p>
<p id="viewer-tbon13513" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>Thank you</span></span></p>
<p id="viewer-q0qr23622" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span> </span><span>Denis</span></span></p>]]></content:encoded>
						                            <category domain="https://anninrobotics.com/forum/general-discussion/">General Discussion</category>                        <dc:creator>mylord</dc:creator>
                        <guid isPermaLink="true">https://anninrobotics.com/forum/general-discussion/wireless-connection-instead-of-usb-cable/#post-1395</guid>
                    </item>
							        </channel>
        </rss>
