AR4 Arduino nano pr...
AR4 Arduino nano problems
Avatar of Jose Marulanda Hurtado
(@jose-marulanda-hurtado)
Hello Chris, my Arduino Nano connects and disconnects constantly, any recommendations to solve this problem.
At times the program stops because it cannot find communication with the Arduino.
thank you.
Sounds like a loose connector, make sure everything is properly connected, swap out the USB cable, and even plug directly into the arduino to the PC without using the keystone connector. See if that helps.
