Can anyone share ho...
Can anyone share how to use 'open vision control'?
Avatar of xie.sam
(@xie-sam)
Hi,
I have successfully installed python. And pyserial, inputs(xbox), numpy as well in CMD window. I also successfully installed opencv-python in CMD window.
I copied the python -- 'cv2.pyd' file to 'site-packages' folder.
But right now the problem is when I open the 'Sentry Project.exe' file then the pop-up window shows ERROR: APP can not start normally (0xc000007b)... 🙁
I search on web it seems miss the .DLL files. But I am sure the 4 DLL files(cv210.dll, cvaux210.dll, cxcore210.dll and highgui.dll ) are already in 'SysWOW64' folder.
Anyone met the same thing to me?
Can anyone share any comment for this issue?
I tried for a long time to get opencv to work and had a similar error to yours.
I downloaded an older version of RoboRealm (1.7.5 i think) which you can find for free with a bit of googling. It worked and was way easier. I had to mess around with the newline characters it was generating for the AR program to correctly open the .txt file.
Let me know if you solve the opencv errors.
Avatar of Rocco Scinto
(@rocco-scinto)
@johann-voigtlander What is the format of the data that the arm is looking for? could you paste a sample?
@rocco-scinto
Hi Rocco,
This is an old post, since then Chris Annin has integrated vision control into his software.
If you look on his YouTube channel for programming the arm there are some times when the serial string shows up.
Cheers,
J
