Chain Sprocket or T...
Chain Sprocket or Timing Belt Pulley
Avatar of Aravinth Kumar
(@aravinth-kumar)
Why you're using Chain Sprocket transmission technique instead of timing belt and pulley in J3? Any specific reason.
I tested a few low profile belts and found they stretched too much. I didnt want to make the arm any wider and was looking for something low profile so I decided on a small 6mm chain.
Avatar of Joseph
(@joseph)
@chris-annin GT3 and similar belts stretched too much? Surprising, I read they are industry standard for some CNC and regarded as a rigid link
(@aravinth-kumar)
Thanks for the reply. I am planning to use GT or SM type timing belt and pulley instead of XL type for all three joints J1, J3 and J4. Whether it will workout?
Avatar of Joseph
(@joseph)
If cost is an issue like it was for me in Australia, maybe try your local engineering supplier. I was looking on ebay and aliexpress at first... our local supplier was actually a lot cheaper, statewide bearings. I got 10ft of it for $30, it was over $100 from other places
