J2 motor not rotati...
J2 motor not rotating
Avatar of Pietro Lori
(@pietro-lori)
Hi everyone,
I'm experiencing an issue with the motor of joint 2 on my robot. When I power it on, all the motors become stiff except for the one on joint 2. When I run the program to check if the encoders are working properly, it shows that the only encoder not functioning correctly is the one on J2. Additionally, when I try to move the J2 motor via the program, I hear a sound like it’s trying to work, but it doesn't actually move.
Any advice on what might be causing this issue or how to troubleshoot it further would be greatly appreciated. Thank you!
Pietro
Can you check the coupler between the motor and the gearbox? There is a small black plastic cap on the side of the gearbox. If you remove the cap you can access the coupler and tighten with a hex key wrench. This has been a common issue lately. I am contacting Stepperonline to resolve. Please let me know if this is the issue.
Avatar of Peter Choy
(@peter-choy)
@chris-annin Also just had this issue on first run (encoders not working, motor making noise but not rotating) and Chris' suggestion was exactly correct. Took the caps off (note there are two), manually rotated J2 with the software until the hex screws inside were aligned with the holes, then tightened. Now motor seems to rotate and encoders are reading sensible values.
(@pietro-lori)
@peter-choy Thanks, tightening the coupler resolved the issue!
(@pietro-lori)
the encoder value oscillates between 1000 and 1001
