Opening ARCS/AR2 fi...
Opening ARCS/AR2 files outside of the program
Sandy Curth
(@sandy-curth)
I'm unclear on what file type the move programs built in the software are. I can't seem to open them with anything outside ARCS/AR2. Can anyone explain?
Basically I have a system running to format positional data for a path from python the same as the machine code in the ARCS/AR2 interface, but I can't seem to actually get it there. Even copy pasting it over would work. Can I add copy/paste functionality to that window in the backend somewhere? Thank you.
Sandy Curth
(@sandy-curth)
Turns out my display resolution was such that the AR2 interface was cut off at the bottom.... I now see the manual entry function! Will update on this grasshopper/python input shortly.
Avatar of Pradeep Devadass
(@pradeep-devadass)
@Sandy Curth Hi, I'm a newbie to AR3/AR2. I understand you are also looking to use the grasshopper and AR3. Please may I know has it worked for you. Also is there a way to enter multiple lines of code exported in another software using the 'Manual Program Entry'.
