Request for J7 Cali...
Request for J7 Calibration Command in AR4 Software
Elijah Peralta
(@elijah-peralta)
Hello. I would like to add an autocalibrate J7 command in tab number 0 in the code so the robot calibrates J7 with the rest of the joints upon startup. There is an Autocalibrate CMD command but nothing for external joints. Is there a way to do this?
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software.avif
I asked ChatGPT, and it gave me some suggestions for editing the software, but I'm not sure if they are correct. I can't share the chat, but here are the screenshots:
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_2.avif
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_3.avif
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_4.avif
This topic was modified 7 months ago by Elijah Peralta
I added some code to a beta version 5.2 for the HMI interface. Here is the source code - I didnt get a chance to fully test but if you have python installed you can try running this. I didnt make a button to insert the command automatically but you can use the manual entry field and insert "Cal_J7" into your program. Let me know if this works - I'll add buttons and clean it up when I get some time and ready to release 5.2 Im not sure about the GPT suggestion but the individual calibrate is already there - I just added and executeRow def for all the individual joints:
##Calibrate J7##
  if (cmdType == "Cal_J7"):
    if (moveInProc == 1):
      moveInProc == 2
    calRobotJ7()
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_5.avif
Avatar of Thu Htet
(@thu-htet)
@chris-annin Hello, thank you for the 5.2 source code. I'm currently running into a problem where after converting the python code to an executable file, the executable file will not load when I try to open it. I have included a screenshot of the problem below. I am currently using Python 3.13.2 and I followed the step-by-step instructions provided in the ReadMe text file. Can you please provide me with further assistance on this issue? Thanks!
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_6.avif
@thu-htet Are there any errors listed in the python console? When you create the .exe you also need to make sure all the supporting files are copied over to your exe folder. You can also just run the py file through python rather than converting to an exe.
https://anninrobotics.com/wp-content/uploads/2025/08/Request-for-J7-Calibration-Command-in-AR4-Software_7.avif
