<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									RoboDK Connection and Post Processor - Questions				            </title>
            <link>https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/</link>
            <description>Annin Robotics Discussion Board</description>
            <language>en-US</language>
            <lastBuildDate>Sat, 04 Apr 2026 07:51:54 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>RE: RoboDK Connection and Post Processor</title>
                        <link>https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2796</link>
                        <pubDate>Sat, 09 Aug 2025 18:21:57 +0000</pubDate>
                        <description><![CDATA[Thanks Chris, I dont think I want to use the old version. It&#039;s a shame that I can&#039;t at least get GCode out of RoboDK to use with the current version of your control program.]]></description>
                        <content:encoded><![CDATA[<p><span>Thanks Chris, I dont think I want to use the old version. It's a shame that I can't at least get GCode out of RoboDK to use with the current version of your control program.</span></p>]]></content:encoded>
						                            <category domain="https://anninrobotics.com/forum/questions/">Questions</category>                        <dc:creator>David Da Costa</dc:creator>
                        <guid isPermaLink="true">https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2796</guid>
                    </item>
				                    <item>
                        <link>https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2795</link>
                        <pubDate>Sat, 09 Aug 2025 18:21:40 +0000</pubDate>
                        <description><![CDATA[This thread has some additional info.I believe you will need to be running the MK1 software version 2.2 for RoboDK.]]></description>
                        <content:encoded><![CDATA[<p><span>This thread has some additional info. </span><a class="KuPfL ggJuS" href="https://anninrobotics.com/forum/general-discussion/robodk-with-ar4-robot" target="_blank" rel="noopener nofollow ugc" data-hook="web-link"><span>https://anninrobotics.com/forum/general-discussion/robodk-with-ar4-robot</span></a><span> I believe you will need to be running the MK1 software version 2.2 for RoboDK.</span></p>]]></content:encoded>
						                            <category domain="https://anninrobotics.com/forum/questions/">Questions</category>                        <dc:creator>Chris Annin</dc:creator>
                        <guid isPermaLink="true">https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2795</guid>
                    </item>
				                    <item>
                        <title>RoboDK Connection and Post Processor</title>
                        <link>https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2794</link>
                        <pubDate>Sat, 09 Aug 2025 18:21:24 +0000</pubDate>
                        <description><![CDATA[I have been playing with RoboDK and my AR4, using the AnninAR4Driver.py I can connect to the arm, however getting any predictable movement from it does not work (unless I am doing something ...]]></description>
                        <content:encoded><![CDATA[<p id="viewer-xkb3d771" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span>I have been playing with RoboDK and my AR4, using the </span><a class="KuPfL ggJuS" href="http://anninar4driver.py/" target="_blank" rel="noopener nofollow ugc" data-hook="web-link"><u><span>AnninAR4Driver.py</span></u></a><span> I can connect to the arm, however getting any predictable movement from it does not work (unless I am doing something wrong.</span><span> </span><span> </span><span>As an alternative route I was looking at using the AnninRobotics post processor to generate code that I can load into Chris's control program just seems to generate a corrupt file.</span><span> </span><span> </span><span>Is anyone currently succesfully using RoboDK with the AR4 arm and if so, any pointers as to what I am doing wrong. (I have read all the previous posts in the forum on the subject).</span><span> </span><span> </span><span>Ideally I would like to be able to create/ simulate moves in RoboDK and either direcly run the arm from there or create a .AR4 file to load into Chris's program or G-Code to do the same.</span><span> </span><span> </span><span>Thanks</span></span></p>
<div id="viewer-ocef17108" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"> </span></div>
<p id="viewer-9fkov7125" class="SpiL2 kjztB _4OSHH wHFxW" dir="auto"><span class="G7Gjj"><span> </span><span>David </span></span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://anninrobotics.com/forum/questions/robodk-connection-and-post-processor/#post-2794</guid>
                    </item>
							        </channel>
        </rss>
