Solenoid valve for ...
Solenoid valve for gripper
4 Users
Pierre-Alexandre Girard
(@pierre-alexandre-girard)
Hi,
I was wondering if someone could share the model of solenoid air valve you are using with your pneumatic gripper. The most common I found on Amazon are the 24V 5 ports (inlet, 2 outputs, 2 vents) 1/4: NPT
I haven't received my gripper yet so I'm not sure if one need a particular type of 2 way valve and if you guys managed to find fittings that will connect the 3mm air lines to these 1/4" ports
Thanks in advance
Avatar of Patrick Sultana
(@patrick-sultana)
Hi Pierre,
The valve I'm using is the 4V110-M5-DC24V available from many sellers on ebay. It has M5 threaded ports, made it easier for me to find respective fittings.
Avatar of makopack
(@makopack)
Any luck finding one on Amazon that works? I'm utterly clueless on pneumatic stuff... I'm not finding anything on amazon with the specific numbers 4V110-M5-DC24V. I see a lot of 4V210 DC 24V...
What are the specific specifications we should be looking for?
Mike Mangan
(@mike-mangan)
@makopack I got that valve, now I’m trying to figure out what other pieces I need to make it work. It didn’t come with any information with it, I don’t even see where are you connect the power yet, haha. Back to the research. I feel this part will take his lawn this building the robot. Ha.
