I built a custom robot and have been setting up all the parameters. I used it to jog the robot around and everything was working. After closing the app I tried to reopen it and the app won't start. I see the black screen... then after a long pause I see the small white window popup and then go away. Nothing after that. I tried restarting the computer and that didn't help.
I finally gave up and installed the software on a new computer and started over. I am now having the same problem on the second computer. After using the app it won't reopen. Even after a computer restart.
How do I troubleshoot, or what is the solution if this has happened others.
Both computers use windows 10 64 bit. I am happy to add any other information you might need.
I can’t recall which file name, u just sort file according modified date time will know the latest changes isn’t it?
you delete your whole folder and download again. i think the parameter you set cause calculation wrong. Every time it happen just re-extract the content (or, remove the setting files)
Update... I redownloaded the files, unzipped and opened the new download on the same computer. It now seems that once I change parameters, or use it a few times it won't open again.
