Understanding of ki...
Understanding of kinematics
Avatar of tc ratius
(@tc-ratius)
Hi Chris and fellow robotians,
I posted this on YouTube, however it may be helpful to other. This is my understanding of the kinematic videos on YouTube in particular episode 6:
So basically, you find the inverse of common positions, which I will call posses, that can be put into a sequence. For example, let us say the first sequence goes to J2 pose as it is the closest move to the object we want to interact with. Once this is achieved the arm then moves in that pose to the object as one unit instead of having to jog the x, y, z individually to achieve the task. Am I on the right track?
I think that sounds correct. I will need to review that video to see which aspect of the inverse you are referring to.
Avatar of tc ratius
(@tc-ratius)
It's ok, you have a lot on your plate, and AR3 wasn't built in a day. 🙂 There was this clue in a CNC mob I follow that are trying to implement a mega robotic arm!
