AR4 MK3 in Finland
AR4 MK3 in Finland
Avatar of JannH
(@jann-h)
Hi!
Finished my build of the AR4 MK3 in Finland some time ago. Even recoded the time the build took me,
52.5 hours of slow, careful and deliberate work.
Ros2 is working thanks to ycheng @ https://github.com/ycheng517/ar4_ros_driver/
Below's a sample with Chris' software (object recognition) and one with ros 2 collision aware IK.
https://anninrobotics.com/wp-content/uploads/2025/07/AR4-MK3-in-Finland.mp4
https://anninrobotics.com/wp-content/uploads/2025/07/AR4-MK3-in-Finland_2.mp4
This topic was modified 9 months ago by JannH
Avatar of JannH
(@jann-h)
Hi all,
brief update. I have done work on the ROS2 solution to include a linear track, Pilz Motion Planner and velocity control (instead of the original position control) for a huge increase in speed while maintaining tolerances, among many other things.
I replaced some of the limit switches with optical switches, added a voltage and amperage display and incorporated a panic button in the code.
https://anninrobotics.com/wp-content/uploads/2025/07/AR4-MK3-in-Finland_3.mp4
https://anninrobotics.com/wp-content/uploads/2025/07/AR4-MK3-in-Finland_4.mp4
I'm using PlotJuggler in testing to validate the velocities, positions and accelerations, it's very helpful.
This post was modified 8 months ago by Peter Kappes
Avatar of Jeffrey C Miller
(@jmarduino)
Great job! Can you provide more detail on the optical switches used and what parts you needed to change?
Avatar of JannH
(@jann-h)
(@jmarduino)
@jann-h
Jann,
Thanks for posting pictures. Was there any code or electronics changes needed for the optical switches?
Avatar of JannH
(@jann-h)
@jmarduino No changes necessary, as long as the switches give the same output as the original - some work in reverse.
Yifei Cheng
(@ycheng517)
Looking great!
Avatar of JannH
(@jann-h)
For anyone interested, here's what the newest velocity control implementation might look like in practice. It allows for over 10 times faster acceleration amd velocity than the original position based control, while maintaining smaller position and goal errors.
@ycheng517 is merging these new changes into his solution, see
(Original trajectory and goal limits are 0.02)
This post was modified 8 months ago 2 times by Peter Kappes
