Can you control the...
Can you control the robot arm with a CNC pcb?
Roy de Kleijn
(@roy-de-kleijn)
Hello,
I'm in the process of a first attempt to create a 100% 3D printed robot arm. I was wondering if anybody was able to control this arm with a CNC board. like: Ultratronics. With this board, you can use smaller stepper drivers and maybe reduce some costs. The advantage might be that you can use code out of the box. Has anybody tried it? are there things that I have to know upfront?
Happer to hear from you,
Roy
Roy de Kleijn
(@roy-de-kleijn)
More importantly: is a stepper driver like TMC2130 or TMC2209 good enough? it has max 2,5 A output.
Roy de Kleijn
(@roy-de-kleijn)
Yeah, got all the bearings and belts today. I got them from: https://www.123kugellager.de
Avatar of rui zhang
(@rui-zhang)
Yes, it is possible to control a 100% 3D printed robot arm with a CNC board like the Ultratronics. In fact, this is a popular approach for hobbyists and makers who want to build their own robot arms on a budget. If you need bearings, you can check https://en.tradebearings.com
Avatar of Jerry Chang
(@jerry-chang)
Ultimately, the decision of whether to use a CNC board or a microcontroller for your robot arm depends on your specific needs and priorities. If you are on a tight budget and want to get started quickly, a CNC board could be a good option. However, if you need more flexibility and functionality, a microcontroller might be a better choice. Check https://www.bearingforworld.com/ if you need to know more
