thrust needle rolle...
thrust needle roller bearing
Mirosław Kupicha
(@miroslaw-kupicha)
what is the specific dimension of a thrust needle roller bearing - 3 pcs
Victor Manuel Castanares Martin
(@victor-manuel-castanares-martin)
You have it in the Robot Arm assembly, it's from shaft 1 ", outside diameter 1- 9/16". The reference is 5909K36 of McMaster Carr, you can look on their website for more information. In Europe I have not found those dimensions exactly, the most similar is the AXK2542, which has a larger external diameter.
Avatar of Friedrich Kuchel
(@friedrich-kuchel)
look here: 123kugellager.de ,NTA1625 delivery to all states in europ
