Home and rest progr...
Home and rest programs for ARCS Ver 1.0 not working properly
Avatar of sfahrngruber
(@sfahrngruber)
Hello,
When running the home and rest programs on the AR3 control software, the robot does not move to the correct locations shown in the tutorial video. All of the encoders are on, but the robot does not seem to know where it is in space. Also, the limit switches do not stop the robot and the only way to stop the robot is to use the emergency stop button.
We are using the teensy 3.5 version 1.53 and the Arduino 1.8.13 softwares on the robot.
I was wondering if there are any suggestions for this issue,
Thank you for your time,
Cheers,
Sam
Avatar of D. D.
(@d-d)
Hi Sam,
I ran into the same issue(s) when I attempted to calibrate the robot for the first time. In short, my solution was to reverse the black and red wire on each limit switch - the manual is incorrect or I introduced an extra wiring error.
Here's what I did:
-> After building the robot, manually positioned the robot to be roughly in the "rest" position, programmed the Teensy 3.5 and established communication with the Teensy in the AR3 control software, and with the robot control box fully powered on, I navigate to the calibration tab.
-> In the calibration tab, I selected the "Calibrate J1 Only" button.
At this point, the machine rotates clockwise, stops, rotates counterclockwise slightly, then clockwise again a little before completely stopping with an error about either the limit was tripped or the joint is out of calibration. From my understanding, the machine should rotate towards the limit switch making contact, reverse direction to release the switch, then re-establish contact with the limit switch before stopping with calibration achieved for that joint / motor / axis.
The issue repeats on all joints / motors / axis. With a multimeter, I read approximately -5V when pressed (ground reference is the ground pin to the GX16-2 connector) and 0V when not pressed.
The solution for myself was to reverse the black and red wires for all limit switches so that I read approximately 0V (pressed) and -5V (not pressed). From here, I can calibrate each axis individually as before, with success.
