Wireless connection...
Wireless connection instead of USB cable
Avatar of mylord
(@mylord)
Hi,
I'm curious what device are you using to connect to the robot wirelessly?
My Robot-Arm will be sitting on a drivable plattform, and I don't want to run behind the AR4 with an USB cable.
I was looking into wireless USB dongles, but not sure if this will work.
Thank you
Denis
If the drivable platform has a network, you could use something like this: https://www.digi.com/products/models/aw02-g300 - i've never used the USB one, but the RS232 ones work great. theres probably cheaper alternatives as well. Another option might be put a raspberry pi (4, 5 or zero - with adaptors), connect it to the teensy and install software called virtualhere https://www.virtualhere.com/ . I've used virtualhere on another project and it worked fine. you'll have to hotspot to the RPI or do some other networking. If you get something working, let us know!
