AR4 v2 Install Issu...
AR4 v2 Install Issue
jimk
 jimk
(@jimk)
Active Member Customer
I'm trying to run the AR4 v2 software on a little laptop. When I kick-off the executable I get a command window flash and then nothing. When I kick-off the executable from a command window I get the following error, "ImportError: DLL load failed".
https://anninrobotics.com/wp-content/uploads/2025/08/AR4-v2-Install-Issue.avif
By the way, I'm trying to run this on the following laptop:
https://anninrobotics.com/wp-content/uploads/2025/08/AR4-v2-Install-Issue_2.avif
As a last attempt, I installed the latest Python version. However, I think AR4.exe includes its own version of Python so this didn't help.
Any ideas?
Thanks,
Jim
I've had a few reports of people having issues after the last windows update. Are you able to run the last version 1.3?
I updated to python 3.10.7 - let me know if this version works https://drive.google.com/file/d/1oeSpcE_og9edJFXOyWsGIs7SqbLw3Ea5/view?usp=sharing
jimk
 jimk
(@jimk)
Nope, version 1.3 had the same kind of error:
https://anninrobotics.com/wp-content/uploads/2025/08/AR4-v2-Install-Issue_3.avif
However, the new 2.1 version does work. Weeeee!
Just one thing, the laptop screen maxes out at 1368x768 which clips the right hand side of the AR4 window. Any easy way to detect small screens and turn on scrollbars? Not the end of the world - this is $60 laptop from Micro Center. I think it's a left over educational laptop. Hard to past up for $60 bucks. I'm hoping it will make a good teach pendant for a AR4.
Below is the full-screen capture. Notice the screen cutoff on the right. Even allowing the screen to be resized by grabbing along the boarder to stretch it would be ok.
https://anninrobotics.com/wp-content/uploads/2025/08/AR4-v2-Install-Issue_4.avif
Thanks,
Jim
Avatar of Toni Habib
(@toni-habib)
I have just downloaded V2.0 of the AR4 HMI, and I have the same problem as Jim with the Main Control page clipped to the right and a bit at the bottom. This makes it impossible to control the robot arm. Is there a fix for this?
BTW, version 1.3 worked fine.
Thanks,
Toni.
