Digital low signal ...
Digital low signal output arduino nano
Avatar of SchruteFarms
(@taylor-cox)
I have a electromagnet coil end effector that needs a digital low trigger to turn on the magnet. Will I need to alter the code on the arduino nano to allow the AR4 software to send a digital low signal instead of a digital high signal? (which I assume is default active high). Or am I overthinking it?
I believe you are correct and would just need to change the output to digital low.
