Help Needed – Teens...
Help Needed – Teensy Hangs and Fails During Welding on AR4 Robot (Possible EMI Issue)
Prashanth Kumar V
(@prashanth-kumar-v)
Hello everyone,
First off, huge thanks to Chris Annin for making the AR4 robot possible. We’ve successfully built the robot, and after overcoming several mechanical and calibration challenges, it now runs smoothly and performs as expected — until we attempt welding.
The issue we're facing is quite critical. When we start welding operations, our Teensy 4.1 controller begins to hang intermittently, and with continued welding, it eventually fails completely. After investigating, we strongly suspect the problem is caused by electromagnetic interference (EMI) induced through the limit switch wiring, which is routed along the robot’s aluminum structure.
We’ve seen other AR4 builds successfully performing welding without such failures, and we’re trying to understand what we might be doing differently — or missing entirely — in our setup. Specifically:
  • Are we incorrectly routing or grounding the limit switch wires?
  • Should we be isolating the Teensy completely from the frame electrically?
  • Would using optocouplers, shielded cables, or ferrite beads on signal lines help?
  • What protection mechanisms are commonly used in successful welding applications with AR4 builds?
We’ve documented our build in a short video which shows how the robot functions and how the wiring is currently arranged. Any guidance or suggestions from those with experience in this area would be greatly appreciated, especially from anyone who’s successfully integrated welding into their AR4 build.
I have used Chatgpt for the above to get my point across without any misunderstandings.
Thank you in advance!
I know this has been an issue for others, here is one post I recall https://anninrobotics.com/forum/questions/custom-robotic-welding-arm I don't know for sure what the solution is, as mentioned in the other post I know a flyover diode eliminates this issues with solenoid valves but I'm not sure about welding. Doing a quick search I find this:
  1. USB Isolation
    • Use a USB isolator board (e.g., ADuM3160-based or commercial models from Olimex, etc.).
  2. Shielding & Grounding
    • Metal enclosure for controller, grounded properly.
    • Shielded USB cables with the shield grounded at one end.
    • Star grounding (avoid current flowing through signal grounds).
  3. Physical Separation
    • Keep all USB, signal, and logic wires away from welding cables.
    • Cross at 90° angles if needed.
  4. Power Isolation
    • Use an isolated DC-DC converter for powering the controller.
    • Or run off a battery to avoid noise from shared AC grounds.
  5. Ferrite Beads & TVS Diodes
    • Place ferrites on USB and signal wires.
    • Add TVS diodes to protect against fast transients on VBUS and data lines.
Hello, I haven't tested myself but I have had people recommend using a USB isolator such as ADuM3160. You might also look at an industrial shielded USB cable as I believe its the USB communication side that's getting interrupted.
