How to remove J1 Mo...
How to remove J1 Motor key?
Avatar of Marek Miettinen
(@marek-miettinen)
First of all: thank you so much for this wonderful project!
I have tried for weeks to remove the key from the J1 motor shaft using locking pliers, as described in the AR3 manual. I was able to get a good grip, but it. does. not. budge. 😥 I have then tried to remove it using a cold chisel. I've chipped a corner of the key off, but it does not move at all even when hammered with the chisel. Any ideas on what to do? Do you know if stepperonline has maybe changed their product recently?
Markku Raiskila
(@markku)
There is one picture how I removed keys in my "AR3 Hameenlinna Finland" build diary at Robot Builds...
(@marek-miettinen)
Thank you thank you thank you! Valtavat kiitokset sulle Markku!
As described in your post here: https://anninrobotics.com/forum/robot-builds/ar3-hameenlinna-finland the key to success was to use side cutting pliers to get a good grip of the key and wiggle it out. I have ruined my cheapo Bebek pliers, but it certainly was worth it 😄
Markku Raiskila
(@markku)
No jos vähän avuks voi olla viikkojen itse yrittämisen jälkeen niin toki olen. Hieno projekti tämä AR3...
