if on jump... dont ...
if on jump... dont work
Avatar of Massimo
(@massimo)
Question, the "if on jump" command does not work, and "if off jump". the arduino entry works, because on the previous line I inserted a "wait on". come can i fix? Thank you.
Avatar of Massimo
(@massimo)
Resolved. change "ser.readline ()" to "ser.read ()".
Avatar of Massimo
(@massimo)
##If Input On Jump to Tab##
if (cmdType == "If On "):
inputIndex = command.find("Input-")
tabIndex = command.find("Tab-")
inputNum = str(command[inputIndex+6:tabIndex-9])
tabNum = str(command[tabIndex+4:])
command = "JFX"+inputNum+"T"+tabNum+"\n"
ser.write(command.encode())
ser.flushInput()
time.sleep(.2)
value = ser.readline() ************************************************this with: value = ser.read()
if (value == b'T'):
index = tab1.progView.get(0, "end").index("Tab Number " + tabNum)
index = index-1
tab1.progView.selection_clear(0, END)
tab1.progView.select_set(index)
##If Input Off Jump to Tab##
if (cmdType == "If Off"):
ser.flushInput()
time.sleep(.2)
value = ser.readline() *********************************************and this with: value = ser.read()
if (value == b'F'):
index = index-1
Thank you for the input, Ill look into why it wasn't working with ser.readline.
Chris
