J3 axle
Avatar of Peter Lingas
(@peter-lingas)
Hi! I have been trying to get my university to machine the keyshaft in a 8mm stainless steel shaft that i had bought (i sourced my own parts except the aluminium kit). But after months they still havent gotten it done, I was wondering if it is possible to order only that part directly from you or if not, then maybe this is the right one from mcmaster carr? https://www.mcmaster.com/products/rotary-shafts/keyed-rotary-shafts-5/diameter~8mm/length~500-mm/
I am using your new belt and pulley kit that is for sale.
Thank you!
Hello, That shaft you linked from McMaster is the correct shaft, I believe that's the best option to purchase. I only have the completed kits right now and would have to remove the shaft from a kit. Let me know if you have any more questions. Thanks.
