J5 linear rods slid...
J5 linear rods sliding
Avatar of ya
 ya
(@ya)
Both linear rods in the J5 assembly are sliding out and in when the J5 motor is activated. I have used the set screws and loctite, but the motor seems like its too powerful and breaks the bond. Has anyone had this problem or a solution to it?
Make sure that the linear rod is pushed in far enough so that the set screw actually bites onto it.
Avatar of ya
 ya
(@ya)
@johann-voigtlander It was, and I had tightened it super tight, but still slipped. I put some bearing compound on it and that fixed it so far.
use locktite on the setscrews too
