Mounting Options - ...
Mounting Options - Roof
Paul McLaughlin
(@paul)
Hi there,
Looking at hanging the AR2 upside down. Is it possible by default? And if not, what should I look at modifying?
Thanks again for all your help!
theres no default setup for inverting the robot. I dont see any issue why you couldnt invert it the way it is and then just be aware that Z+ is down and Z- is up. Other than that it shouldnt be an issue. I have had a couple industrial robots inverted - and there are settings to invert the robot relative to payload calculations but the base frame stays inverted as stated - the AR2 does not have have servo feedback for payload or payload settings so it should be fine.
Paul McLaughlin
(@paul)
Awesome. Thank you for your quick response Chris. I'll be working on inverting it over the next few weeks and will share any problems/solutions I run into 😀
Avatar of Myles Keane
(@myles-keane)
Hi Paul,
I am new to the AR2/3 and also considering to hang it upside down.
What was your experience? Did you run into any problems?
(@myles-keane)
Hi Paul,
thank-you very much for the quick response. I will try it early next year.
