Pneumatic Valve Wir...
Pneumatic Valve Wiring
hube268
(@hube268)
Hi Chris,
I'm just about finished with my AR2 and ran into one issue with wiring up the pneumatic valve. In the picture of on Pg33 of the Electrical Enclosure manual, you have a small picture of the solenoid valve with the flyover diode. In that picture you have a 3-wire connection however in the picture right next to it, You just have a +24v and -24V connections... Is the 3rd green wire just a ground wire?
Also, are the arrows for which screw terminals on the relay board correct? It seems its pointing to the NO and NC pins, however that means there will never be a connection no matter if the relay is activated or not right?
Thank you!
Hello, yes the green wire is ground. The red,blue,green strip wire was what I had on hand at the time, I will take better pictures with correct wire colors. The arrows were meant to be generally pointing to the relay board not the specific terminals - I will also get a better diagram of that where it points to the correct terminals.
hube268
(@hube268)
Thanks Chris! We got everything working well now. I'll post a video of one of our first tests in the builds forum. There is still a bit of adjusting to do but overall working well. Thanks for the help!
