RoboDK problems?
RoboDK problems?
Avatar of ttrobotics
(@ttrobotics)
I installed the RoboDK application. But even though I connect, the robot coordinates do not change. The robot does not respond. Does anyone else have this problem?
Avatar of mateomcg11
(@mateomcg11)
Hey! Im in process of connect the AR4 robot with RoboDk but I have some Python problems and Im fixing it, but the post processor of robodk its wrong to. So if you chande the post processor with the parametrs of command that chris publish on cmd example, the post proccesor works well in offline programming.
(@ttrobotics)
@mateomcg11 did you fix the problem AR4 RoboDK link is working?
