Was fine calibratio...
Was fine calibration removed?
Oliver Johansson
(@oliver-johansson)
Active Member Customer
I've been struggling with repeatability on my AR4 a lot and have seen a fine calibration feature referenced in a few places, most notably the info tab in the AR4 software.
Has this feature been removed or is it just somewhere I can't find it?
Also while I'm at it, is it possible to add the 7th axis to the "Auto Calibrate command" somehow?
Thanks for any help,
Oliver
Earlier in the AR2 software I had a fine calibration feature that allowed you to modify the calibration based on a reference position. I replaced that process with calibration offsets which allows you to use a digital level to modify calibration angle to compensate for any variation in the limit switches. Currently the 7th axis calibration is stand alone but I will look into adding that to the autocalibration.
