What does correctPo...
What does correctPos function do?
Avatar of ya
 ya
(@ya)
What does the correctPos ("CP" serial command) do? It seems to only get called on a collision, but I don't understand why it recalculates / resets the position based on the encoder only upon collision.
If a crash is detected then it uses the encoder value to reset or correct the position to what the encoder says it should be.
Avatar of ya
 ya
(@ya)
@chris-annin So you assume calibration is wrong if there is a crash and attempt to fix it?
