My first AR2 Robot ...
My first AR2 Robot test build
Avatar of Tatyana Uzunova
(@tatyana-uzunova)
Almost one month since I started to work on the project. 🙂 For my first test I decided to use 3D printed files, and since i have a 3D printer it was pretty much doable.
The small problem which I faced difficulties is part - 60T Timing Pulley Hub. I am not able to find it anymore in ebay, as well in other shops. I really hope someone could share a thought where could be possibly found?
I post also a video of first parts assembly : ))) It works pretty neat : )
I am waiting to receive the pack with stepper motors 🙂 I really like the whole project and I can not express my joy! Thank you for the hard work and all shared knowledge! Greetings from Slovakia, Bratislava.
Sincerely,
Taniq
This topic was modified 8 months ago by Tatyana Uzunova
Zach Allen
(@zach-allen)
Looks like I'm late to this...but this is where I bought my timing hub from:
https://www.robotshop.com/en/60-tooth-timing-hub-pulley-1-bore.html
Zach Allen
(@zach-allen)
Sent to info@anninrobotics.com
(@tatyana-uzunova)
Hello Chris, I found also a 3D file that I printed out but unfortunately it looks quite unstable. So I found company here who would like to make the part on their cnc machine from stainless steel. As soon as I get results from them I will also update my post here.
Thankfully Tatyana
(@tatyana-uzunova)
Hello Chris, thank you for the quick response. I see it is out of stock, but it has also a drawing for the part, so i am gonna use it as reference and build new from scratch : ) Smile,
Taniq
awesome, thanks for sharing your progress. you can find the timing hub here: https://www.servocity.com/timing-hub-pulley
