How are joints step...
How are joints steps limit calculated?
Avatar of Michel Schneiderman
(@michel-schneiderman)
Hi
I’m building my AR2 and I’m using a different gear ratio with joint 4 motor (1/51), instead of (1/19) , how can I adapt the software to get a correct joint jogging
thanks
I have some info in this video
you will need to change the step lim value on the calibration tab to be the actual number of steps that it takes to jog J4 from -165 to +165.
Avatar of riani.akram
(@riani-akram)
Thank you for your replay
I did change the Ang limit value and it works fine for the position jogging but the spee and acceleration still very slow because of the large gear ratio (1/50)
