Properly wiring the...
Properly wiring the Teensy - the 5VDC connector mystery
7 Users
Pierre Freyssinet
(@pierre-freyssinet)
Current status: AR3 and control box assembled and wired. Continuity checked. ARCS software acknowledges it is connected to Teensy 3.5 and AT Mega (log files). Test of individual Joints is INOP for all joints (in jog mode).
Possible issue: Going through the whole documentation again, we found that we have not wired the Teensy to the 5VDC Supply to robot connector as it is instructed on page 279 of the AR3 documentation. Actually, none of the pictures printed on the Manual shows any wire/jumper plugged into the Vin or upper left GND port of the Teensy, but thos does not estbalish it should not be. We find it a bit odd to connect a jumper from the Vin and GND ports of the Teensy directly to this aviation connector (who is itself connected on one end to the 5DC power supply, via the DIN rail).
Our question: should we connect the Teensy directy to this connector, or via the DIN rail? A revised wiring diagram, even hand-sketched, would be appreciated.
Thanks you for your kind help.
Avatar of D. D.
(@d-d)
Hi Pierre,
I noticed the same wiring error as you have while I've been reviewing the manual for the AR3, as I prepare for my own build.
I also searched these forums for a possible answer but I did not find one. The following posts remained unanswered:
https://anninrobotics.com/forum/robot-builds/ar3-building-wiring-completed
https://anninrobotics.com/forum/questions/5v-psu
Here's my understanding:
The pictures from page #238 to #241 shows two pairs each of black and red wires coming from the 4th pair (black) and 5th pair (red) of the DIN rail terminals. This is where the manual is missing the instructions to add this second pair of wires, including the instructions to solder said wires to the GX16-2 plug on the enclosure door even though the pictures show the installed wires.
If you then jump to page #265, this is when you solder another pair of 22awg wires (black and red) to the GX16-2 plug on the enclosure door. The other end of these wires need to be soldered, with heat shrink, to a pair of jumper wires, which are then connected to the Teensy 3.5 appropriate pins as instructed on page #265 (bottom image). This is how the Teensy 3.5 derives it's power. From 5V power supply unit, to the DIN rail, to the GX16-2 plug, to the Teensy 3.5. Please note, that it is my opinion that the red jumper wire mentioned on page #258, is the same red jumper wire that will be soldered and connected to the Teensy 3.5 Vin pin on page #265. We're missing the follow through on that instruction, including the making of the black wire.
As you can tell, there are missing steps in the manual. Perhaps the community will help with the next revision?
So to answer you're question, from what I can tell, yes to either of your methods asked. The power for the Teensy 3.5 is ultimately derived from the 5V connection point on the DIN rail, which as you know, is sourced from the 5V power supply unit. What's the best method regarding common grounding techniques is another question I choose to side-step for now 😉
Hope that helps Pierre so you can continue with your build.
Would you mind sharing whether you're building the aluminum or 3D printed version?
Separate but related to your post, I'm confused by where the missing +V side of power for the Arduino Mega 2560 is coming from. I can only assume the power will then be derived from a direct connection via the USB cable to a PC and the -V side for establishing a common ground. According to the datasheet, "The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable."
As instructed in the manual, we're not using 5V from the Arduino for the relay module, however, it's the "board may be unstable" part that leaves me uncomfortable. Are they referring again the stability of the 5V output from the Arduino, or the boards ability to function properly? I'm thinking the latter but I would like to hear other's opinion on the matter.
Regards,
D.D.
Pierre Freyssinet
@d-d Hello D.D. and thank you for your detailed answer. First things first: I am building - well, have actually completed the built - of the aluminium version. And had in mind since the begining that I would then try the full 3D printed version, less stiff but probably much lighter, in a second step if I feel confortable with V.1 (our project is to mount a robotic arm on a wheelchair, so there will be quite some hacking on the AR3 current 3-tier architecture (arm / enclosure box / control "big" box). As for my wiring problems, they originated from the fact I was following the instructions of an obsolete version of the manual (I downloaded it in jan 2020 and a revised version had been publised since). Chris Annin is kindly helping me on that matter. So, if I'm not mistaken, the GX16-2 should be connected directly AND only to the Vin and GND upper ports of the Teensy, and the Teensy should be powered only via the USB connection to your PC. In other words, the encoders and limit-switches are powered via the Teensy and share the same ground with the said Teensy. The 5vdc power supply is only needed - I guess - for the Mega, and in my case, I will have a limited use of the Mega and probably none of the 8x Relay board, since I plan to use an electric gripper. I still have a couple of tests to perform today, guided by Chris's instructions, and I'll keep you posted. Kind regards, Pierre
Avatar of D. D.
(@d-d)
Hi Pierre,
"...and the Teensy should be powered only via the USB connection to your PC."
From my understanding, you have two options to power the Teensy.
1) USB connection to PC.
2) Wired either to the GX16-2 connector (provided the connector is wired to the DIN rail for 5V), or wired directly to the DIN rail for 5V.
Also, I believe you can do both simultaneously and the Teensy will automatically decide which one but don't quote me on that. To me, this makes sense since you might have it powered independently from the USB cable but at some point need to reconnect the USB cable to upload a new program.
Spec's for the 2 boards:
Teensy Vin: 3.6-6 volts (link)
Mega 2560 Vin:
Limits = 6-20 volts
Recommended = 7-12 volts (link)
And this is where I have an issue using the 5V power supply for the Arduino. The Arduino operate at 5V but has a low limit of 6V with 7V being recommended. This is why I'm looking at adding a second power supply for the Arduino.
Other items related to wiring:
I noticed that J4 driver (DM320T) Opto pin is powered via the 3.3V output pin from the Teensy. The datasheet (link) says the typical voltage is +5V but fails to say the minimum or maximum. It's a guess that 3.3V is sufficient.
This same voltage is connected to the PUL/DIR signals for the other drivers (DM542T), however, the datasheet for this driver (link) says 4-5V. Maybe I'm being picky, but a weak signal could cause potential issues. On this issue, I'm tempted to use the 5V power supply for these connections instead of connecting it to the Teensy.
The other change I'll be implementing in my build, is running separate power supply lines for each individual driver, rather than daisy-chaining them as noted in the datasheets.
I don't mean to be nit-picky. I know builds of this nature can have bugs to be worked out and perhaps this information will be beneficial to someone in the future when they run into confusion or issues.
Pierre Freyssinet
Well, that is relly interesting and meaningfull, D.D. Right now, I have liaised directly with Chris to kind of debug my own build. I'll raise those questions/suggestions of yours with him.
Avatar of jackyqweasd984
(@jackyqweasd984)
@pierre-freyssinet
Hi Pierre, did you get feedback of the Teensy powering? I run into the same problem during wiring. Thanks!
If both Teensy and Mega 2560 are powered by PC's USB, does it have same ground as the 5V PSU?
Avatar of Lee Cassam
(@lee-cassam)
Looking at the confusion in the manual, I decided to do a few mods. The 5V PSU will only power the limit switches and the encoders. I then decided to power the teensy, relay board and the mega from buck converters to get the correct voltage to each which means that they will be permanently powered, but then cut the red wire in the USB cables so they are not powered from the USB. Unfortunately, I have still got to complete the AR3 build, but I have wired it up outside of the control box and it seems to work okay. We will see what happens when it is finally put ino action.
Hello all, Im sorry I missed this post. Raymond Kimber brought this to my attention and he may have some additional info to add to this topic. Please note that in the earliest version of the manual I had the teensy, arduino 5v supply and the relay board on a common ground and the 5v supply was also sent to the robot to power the encoders and limit switches.   The overall purpose of the 5v supply is simply to power the relays as the arduino (usb 5v) does not have enough amperage to power the relays.  I found using the 5v supply to power the robot encoders wasn't ideal.  In the current architecture to reduce noise the teensy usb 5v powers the encoders and the limit switches and does not share a ground signal with the 5v supply and the 5v supply is only wired for the relay board.
Avatar of Ray Kimber
(@ray-kimber)
Thanks, Chris. I just want to list the specific statements that I sent to you in an email and you confirmed, along with a hand drawn schematic (see below). This may break it down even more so.
1. Both microprocessors (Teensy and Mega) are being powered by the +5V from their respective USB ports. This is labelled +5V/GND.
2. The Teensy +5V powers the GX16-2, which powers all the robot’s encoders and limit switches. The GX16-2 actually connects to the Teensy's Vin pin, but in the Teensy schematic, internally, Vin is connected to the USB's 5V. Additionally, the Teensy's +3.3V output powers the stepper motor drivers’ PUL+ and DIR+ inputs.
3. The Mega’s USB port also provides +5V/GND, but it just powers the Mega board.
4. The 5V power supply provides separate power, labelled +5V1 and GND1. This gets connected to the DIN rail, and powers the relay board. Since I am using a servo gripper instead of a pneumatic one, I will also run this +5V1/GND1 power to a GX16-4 connector dedicated to the gripper.
5. GND1 also gets connected to the Mega board ground, which internally connects it to the GND ground from the USB port.
One Question: earlier in this post (e.g., D.D., March 18) the question was raised about whether 3.3V was adequate for inputs to the stepper drivers. Given that the Teensy's 3.3V is derived from the USB's 5V input, and this 5V appears at the Vin pin, could we power the stepper driver inputs from Vin instead of the 3.3V pin, and better meet the specs of the drivers?
Thanks, Ray Kimber
Brandon Hacken
(@brandon-hacken)
Active Member Customer
The Teensy 3.5 is expecting an input when I connect a wire to the Vin pin and disables power from the usb. The current wiring schematic in the manual and explained above does not work with this Teensy logic. I'm slightly confused on why this has not happened to anyone else on this forum. Did I miss a step that disables the Teensy 3.5 Vin pin logic?
Brandon Hacken
(@brandon-hacken)
Never mind ^ I have a shorted wire somewhere on the robot wire side. All USB ports offer overload (implies short-circuit too) protection so that is why my Teensy would disconnect. Using a multimeter I found that I have continuity on the red and black 5v wires. Visually all the red wires go to red 5V and black wires go to black 5V so this will be fun to debug. Sorta wish I took the time to redesign / make the robot wiring a little more fool proof and easier to work with (wiring is really tight and hard to visually and physically work with). I'm open to suggestions but I think my only path forward is to start undoing all the robot arm 5v wiring until I find non-continuity because visually all the wires match up with their correct color.
Brandon Hacken
(@brandon-hacken)
I found the problem and I am documenting it here: https://anninrobotics.com/forum/questions/shorted-5v-connection-because-of-bent-j1-limit-switch-terminals
