Vertical Movement S...
Vertical Movement Stability with Laser Crosshair on End Effector
Avatar of Alon Borenshtein
(@alon-borenshtein)
To evaluate the accuracy of vertical movement on my AR4, I attached a crosshair laser to the end effector and aimed it at a fixed point on the table. I then moved the robot up and down along the Z-axis (Tz). I expected the laser crosshair to remain fixed on the same point, but noticed that it shifts slightly, indicating some deviation.
I'm trying to determine whether this behavior is due to my specific build or if it’s a software/control limitation inherent to the AR4 system.
have anyone observed similar behavior in AR4 builds? Any insight would be appreciated.
Thanks!
Alon.
End Effector with laser crosshair
Sorry for the late reply on this. Could you try running the latest software version 6.0 and then report back? I found some issues with the incremental jogging and the encoder output that could have been causing some issues.
