How to connect to A...
How to connect to AR4 on RoboDK?
4 Users
Orçun Oruç Aykaç
(@orcun-oruc-aykac)
As I said in the title, How to connect AR4 on RoboDK? On connection to Robot window on RoboDK, I choose:
Robot IP/COM: COM5 (This is my Teensy 4.1 port) Robot Port: 9600 (This is baud on Teensy Sketch)
I cannot connect by this way. Is it correct?
Avatar of bhamze
(@bhamze)
Following. I wasn't aware they released the driver. The library doesn't show the AR4.
Orçun Oruç Aykaç
(@orcun-oruc-aykac)
@bhamze @Johann Voigtlander no, but you can download it to use trial. -> https://robodk.com/download
@bhamze @Orçun Oruç Aykaç thanks, and can it run gcode?
Orçun Oruç Aykaç
(@orcun-oruc-aykac)
@bhamze @Johann Voigtlander Not sure, but I guess you can.
Avatar of bhamze
(@bhamze)
Did you figure a way to connect? RoboDK released the driver but I'm having same issue you are. Any recommendations?
Orçun Oruç Aykaç
(@orcun-oruc-aykac)
@bhamze I solved. Write COM to the Robot IP/COM: field and "your com port number" to the Robot Port: field. Don't use baud.
Nhan Truong
(@nhan-truong)
Hi! So how exactly the way that you successfully connect AR4 to the RoboDK software? I tried the following as u said but it turned out connect failed:
Robot IP/COM: COM
Robot port: 6 (which is my Teensy port)
