Annin Robotics Community
  • Paolo Gagge@gagge· 212 viewsin Robot Builds
    PaMiLoCELL **#09** – Brainstorming and Cell Layout - **AI SIMULATION SCENARIO**
    At this stage of the PaMiLoCELL project, I am carrying out a high-level brainstorming exercise to understand how the robotic cell could evolve before freezing the final layout.
    The objective is not only to define the physical arrangement of the cell, but also to evaluate whether the project can develop into a technically credible and potentially fundable concept.
    Step 0 – AR4 Operating Envelope Analysis
    The starting point is the AR4-MK5 working envelope: maximum reach, inner non-reachable area, joint limits and the difference between theoretical reach and the actually useful workspace.
    Step 1 – Base Cell Layout
    The first concept uses a central inspection/pick area with sorting bins distributed around the perimeter, keeping the first development phase simple and easy to validate.
    Step 3 – Safety + AI Vision Integration
    The next evolution introduces the enclosure, E-stop/reset functions, PLC/safety architecture and AI Vision for object recognition and material sorting.
    Step 4 – Modular Expansion with Conveyor
    A modular/openable side could allow a small conveyor to be added later without redesigning the entire cell, moving from a static demonstrator toward a more dynamic sorting system.
    Beyond the layout itself, I am also starting to look at the project from an innovation and funding perspective:
    • What is genuinely innovative compared with the current state of the art?
    • Which technical problem does the solution solve, and for whom?
    • Can the concept improve existing solutions in performance, flexibility, safety, maintainability or cost?
    • Is there a real market/user need behind the technical idea?
    • How does it compare with existing and competing solutions?
    • What are the main technical and market risks?
    • Which elements could generate proprietary know-how, IP or potentially patentable solutions?
    • Can the concept be validated through measurable technical and economic KPIs?
    This changes the brainstorming process: the goal is no longer only “Can I build it?”, but also “Why should this solution exist, and what measurable value can it create?”
    Questions I am currently asking myself:
    1. What innovative aspects can I introduce compared with the current state of the art?
    2. Is reducing construction and maintenance costs alone enough to create meaningful innovation?
    3. Which measurable benefit would make this solution attractive to a real industrial user or investor?
    4. Which technical result should I demonstrate first to reduce the project risk and strengthen a future funding application?
    Note: The images shown in this post are AI-generated concept simulations created to support layout studies.
    Analyze → Design → Validate → Improve
    #PaMiLoCELL #PaMiLoLAB #Robotics #IndustrialAutomation #RobotCell #AR4MK5 #AnninRobotics #AIVision #MachineVision #FunctionalSafety #PLC #AutomationEngineering #MaterialSorting #Innovation #TechnologyTransfer #OpenSourceRobotics
    PaMiLoCELL **#08** – Robot Transmission Mechanisms
    While assembling the AR4-MK5 and studying industrial robots, I am realizing that robot motion is not only about motors, software and kinematics.
    Between the motor and the joint there is a fundamental element:
    the mechanical transmission.
    Its architecture directly influences torque, stiffness, inertia, backlash, vibration, accuracy, payload and dynamic behaviour.
    Main transmission families used in robotics include:
    • Gear trains – robust and stiff torque transmission.
    • Planetary gearboxes – compact, efficient and with high torque density.
    • Cycloidal / RV reducers – high stiffness, low backlash and high load capacity, often suited to the main robot axes.
    • Harmonic / Strain-Wave drives – compact, lightweight and with very low backlash, often used where low inertia is important.
    • Timing belt & pulley systems – transfer motion between separated shafts and allow more flexibility in motor positioning.
    • Direct drive – eliminates intermediate transmission stages, but requires high-torque motors.
    A useful distinction is also between robot axes.
    J1–J3 mainly position the arm and normally manage higher loads and moments, so torque, stiffness and load capacity are critical.
    J4–J6 mainly control wrist orientation, where compactness, low mass and low inertia become increasingly important.
    Where does the AR4-MK5 fit?
    The AR4-MK5 uses a hybrid mechanical transmission architecture rather than a single transmission technology.
    During assembly, several axes clearly show a chain based on:
    Stepper Motor → Pulley → Timing Belt → Pulley → Shaft / Joint
    combined with couplers, shafts, keys/keyways, bearings and mechanical reduction stages.
    So the AR4 can be associated mainly with a:
    Timing Belt & Pulley + Mechanical Reduction architecture.
    This allows the motor to be positioned away from the joint and the transmission ratio to be adapted to the required motion.
    The basic principle is:
    Motor: high speed / lower torque → Reduction → Joint: lower speed / higher torque
    or, in simplified form:
    Tjoint ≈ Tmotor × i × η
    where i is the reduction ratio and η the transmission efficiency.
    This is also why small assembly details matter.
    Incorrect belt tension, coupler tightening, key fit, shaft alignment, bearing preload or backlash can later appear as:
    lost motion, vibration, reduced repeatability or positioning errors.
    Key takeaway
    Same 6-axis architecture does not mean the same mechanical behaviour.
    Robot performance depends not only on software and kinematics, but also on what happens mechanically between each motor and joint.
    For PaMiLoCELL, assembling the AR4-MK5 is therefore also a practical way to understand how belts, pulleys, shafts, bearings and reduction systems work together to create robot motion.
    #PaMiLoCELL #PaMiLoLAB #AR4MK5 #Robotics #IndustrialRobotics #RobotMechanics #MechanicalTransmission #TimingBelt #Gearbox #MotionControl #RobotKinematics #MechanicalEngineering #Automation
  • Paolo Gagge@gagge· 214 viewsin Robot Builds
    PaMiLoCELL **#07** – Robotic Wiring | Continuous-Flex CAT5/6, EMI/RFI Shielding & Sn100 Soldering
    Another AR4-MK5 integration step: building a reliable moving cable harness.
    In robotics, wiring is not only about electrical continuity. It also means managing flexibility, electromagnetic compatibility, mechanical stress and maintainability.
    For the AR4-MK5, shielded and stranded continuous-flex CAT5/6 is used for encoder, Hall/limit-switch and other low-level signals. The outer jacket is removed where required so the twisted pairs can be separated and routed through the arm.
    Key points learned during assembly:
    1) EMI/RFI shielding protects sensitive feedback signals from noise generated by stepper motors and switching electronics.
    2) Braided sleeve provides mechanical protection and cable organization, but does not replace electromagnetic shielding.
    3) 20 AWG flexible silicone wires are used for motor phase extensions, keeping power and signal wiring clearly differentiated.
    4) Controlled service loops allow the cable to move without transferring unnecessary stress directly to terminals or solder joints.
    The first soldering operations are now being performed directly on the assembled robot, where real constraints such as access, routing, bend radius and moving joints become part of the engineering problem.
    A further challenge is the use of Sn100 lead-free solder.
    Compared with Sn63/Pb37, Sn100 requires higher working temperature and different process control. My goal is therefore not to assume that Sn100 is inherently better, but to engineer the harness so the soldered area remains outside the main cyclic bending zone. With Sn99.3/Cu0.7 at 370 °C I get more uniform wetting and a thinner bead. When soldering with 67/37, a small ball forms at 340°C, which I find difficult to remelt using flux and a soldering iron.
    Initial pull tests showed no cable damage. The next reliability measures are based on:
    large bend radius + service loop + heat-shrink + strain relief + controlled cable routing
    The objective is to keep the rigid soldered zone mechanically protected while maintaining stable, low-resistance electrical continuity during robot motion.
    This is exactly the kind of engineering challenge I want PaMiLoCELL to address: combining mechanical design, electrical integration, EMC awareness, reliability and future AI-based automation in one practical robotic platform.
    #PaMiLoCELL #PaMiLoLAB #Robotics #IndustrialAutomation #EMC #EMI #RFI #CableHarness #Soldering #RobotWiring #ElectricalEngineering #ReliabilityEngineering #Engineering #LearningByDoing
  • Peter Kappes@pkappes· 394 viewsin General Discussion
    First AR4 integration tests from Ares.
    Thanks for sharing!
  • Annin Games@annin-games· 470 viewsin General Discussion
    Best scores of the day
      Loading comments…
