ttrobotics@taylantarhan· 462 views
Auto Calibrate?
I built the robot.However, there is a mismatch in the calibration settings .I'm sending the link to the video.Every time I click on a joint, it moves.But it doesn't work when I define the joint coordinates.Also, it doesn't stop at the position in the simulation, it calibrates in a different position every time I calibrate..Please take a look. Where could I have made a mistake?
ttrobotics
(https://anninrobotics.com/community/questions/auto-calibrate) Annin
Could you please make a teamviewer connection? To get faster results. Will you also see the robot's reactions?
