Auto Calibrate doesn't work properly
I built AR4. I use software and sketch version 3.0. When I try to check all joints and try to auto calibrate, joints don't stop when they reach to limit switch. They keep moving until they break down limit switches. But calibration works when I try to calibrate only one joint.
Why they don't stop?
You will need to check each limit switch and make sure it is returning 0 volts or ground to the Teensy board when the switch is not made and then returns 3.3 when the switch is made. The board inputs are very susceptible to floating voltage so it's important that when the switch is not made that each input pin is getting a solid ground signal.
When I measure voltage at the brown and brown with white strip color in the box behind robot, which the cables and motors are connected inner, voltage is 4.06. (I think it should be 3.30v) I tried to unplug GND (brown with white) from teensy board than voltage is 0.96v. It should have been 0, shouldn't it?
Orçun Oruç Aykaç
I found the problem. It's simple. The problem is because of GND. Because GND signal doesn't reach the limit switches, this error appears.
