Guenter@guentervogele· 861 viewsin General Discussion
Camera Mount on AR4
Hi there, Is it possible to mount the Camera direct on the Robot or have i to make it static over the aeria over the Robot?
Comment1
Hello,If you are referring to using the camera for vision-based part finding or robot picking, then the camera should be mounted in a fixed position above the pick area. It will also need to be calibrated using the vision grid for accurate results.
