Aravinth Kumar@aravinthkumar· 609 viewsin General Discussion
Chain Sprocket or Timing Belt Pulley
Why you're using Chain Sprocket transmission technique instead of timing belt and pulley in J3? Any specific reason.
I tested a few low profile belts and found they stretched too much. I didnt want to make the arm any wider and was looking for something low profile so I decided on a small 6mm chain.
