Mirosław Kupicha@miroslawkupicha· 450 viewsin General Discussion
chain transmission
Is it not possible to fit toothed belts instead of a chain transmission? what was the chain's assumption dictated?
Hello, yes you can use any sprocket or belt pulley that you like. I found that the LX belt had too much stretch for J3 so that is why I chose the chain, but if you upsized to a larger beltsmay work just fine.
