Kstan Simit@kstan· 375 views
Connect female jumper wire to driver without pin?
Hi Chris,
User manual, it show the image as below, the jumping wire (female head) shall connect to driver. I tried it can fit into hole, i can screw it but i not sure it can connect as it is, cause there is no pin inside, i feel it not connect the metal if I not do something
Kstan Simit
End up I remove top side of head so that it can contact the drive connector
