Hans Vertongen@hansvertongen· 997 viewsin General Discussion
Difference between AR2 and AR3
Is their a big difference in parts between the AR2 and AR3?
For example: Can I use the AR2 electrical encloser for the AR3?
So the bulk of the cost of upgrading is just the motors it sounds like https://www.omc-stepperonline.com/only-motors-of-ar3-open-source-robot-package-kit.html I am about 85% done w/ my AR2 but it got stalled when my dad got sick...I think I'm going to just go for upgrading it to the AR3 since I can re-use so many of the parts. At first I thought I needed new aluminum kit, hardware kit as well as stepper drivers.
The primary difference is the dual shaft motors, encoders, teensy 3.5 control board and updated wiring and print files. You can definitely use the same enclosure.
