Massimo@asbockmassimo· 499 viewsin General Discussion
if on jump... dont work
Question, the "if on jump" command does not work, and "if off jump". the arduino entry works, because on the previous line I inserted a "wait on". come can i fix? Thank you.
Comment 3
Massimo
Resolved. change "ser.readline ()" to "ser.read ()".
Massimo
##If Input On Jump to Tab##
if (cmdType == "If On "):
inputIndex = command.find("Input-")
tabIndex = command.find("Tab-")
inputNum = str(command[inputIndex+6:tabIndex-9])
tabNum = str(command[tabIndex+4:])
command = "JFX"+inputNum+"T"+tabNum+"\n"
ser.write(command.encode())
ser.flushInput()
time.sleep(.2)
value = ser.readline() ************************************************this with: value = ser.read()
if (value == b'T'):
index = tab1.progView.get(0, "end").index("Tab Number " + tabNum)
index = index-1
tab1.progView.selection_clear(0, END)
tab1.progView.select_set(index)
##If Input Off Jump to Tab##
if (cmdType == "If Off"):
ser.flushInput()
time.sleep(.2)
value = ser.readline() *********************************************and this with: value = ser.read()
if (value == b'F'):
index = index-1
Thank you for the input, Ill look into why it wasn't working with ser.readline.
Chris
