Daniel@daniel· 415 views
J1 Turret Housing
I recently got the AR3 robot kit and when placing the #32009 races in the J1 Turret Housing, the races got stuck so I put the J1 turret housing in the freezer, and after I took it out the races were firmly in the housing, but after a couple days it became loose again. My question is how should I get the #32009 races to fit inside the turret housing, should I put the turret housing in the oven and the bearing races in the freezer again? Or should I do it another way?
Comment5
When the races were stuck how close were they to being fully seated in the housing? I assume when you say they are loose again, that you now have them back out of the housing?
Daniel
They were pretty close to being fully seated in the housing and I do have them back out of the housing now
You said they firmly in place but became loose, if you were to reinsert them now are they loose and not staying pressed in?
Daniel
When I try to reinsert them now, they are loose.
Kstan Simit
try rotate it to find best fit? Or solution like below fix:
