Matt Carrier@mattcarrier· 474 views
J2 spindle too tight with bearing #30206
Anyone else run into this issue? I was thinking of sanding down the spindle slightly in case I need to ever replace the bearing later. If I press fit I don't think I'll ever be able to get it off again. What did everyone else do?
I have had a couple other people mention this is tight. A polish with some 2000 emery paper or scotch-brite should alleviate. Ive had the tolerance opened slightly on future kits.
