David T. Phan@davidtphan· 434 views
J4 Motor gets hot
Hello, I have noticed that J4 motor is hot to touch comparing to J1-J3,J5,J6 motors. Is that normal or something wrong with the motor in my AR4 set up?Even at idle J4 motor is much warmer than other motors
Comment 1
The motors can get fairly warm but if its uncomfortable to touch then I would say its too hot and I would suggest turning down the driver amperage setting and see if that decreases the temperature.
