Mitchell Panek@mitchellpanek· 803 views
J5 Calibration Issue
I am having issues with my J5 calibration. I have confirmed (to the best of my ability) that the limit switches, encoder and stepper are all functioning and correctly configured. However when I run the calibration routine the Axis rapidly moves in the + direction until the motor stall with the J6 plate touching the arm. I tried reversing the travel direction but it didn't seem to recognize hitting the limit switch that way. Any ideas on what I should try next? Thanks!
can you email a quick video showing the calibration with the J5 side cover removed so I can see what you are referencing relative to the J6 plate.
Mitchell Panek
Chris,
Link below, I also should mention that if I force calibrate it seems to behave correctly.
https://photos.app.goo.gl/MU7PC6PagzXff9f97
